I think my speakers exploded
Username: Tips
Post Number: 85
my front left speaker stopped working. i installed a alpine 9845 and im using factory speakers. is it a loose wiring problem? sometimes it works. sometimes it doesnt. when it does it kinda crackles.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 64
most factory speakers are only rated at like 5 watts peak. you went from 5 watts or less to 18-26 watts. your over powering them by like 3 times, lol
Username: Kklagge
Post Number: 100
Then again it could be a loose wire if that's the only speaker that is affected.
Username: Tips
Post Number: 86
yea, i kno im over powering them, but im not actually turning up the volume too loud... i think. damn it, ill just go remove it and check the wires.
Username: Rds11
Louisville, Kentucky
Post Number: 109
Whenever you get an aftermarket H.U. you should always replace the factory speakers. Especially with getting an Alpine Receiver which are very good, if you haven't already then you will blow your speakers. get new ones
Username: Tips
Post Number: 97
i will be getting new speakers, but its hard for me to decide which ones... heres what ive got so far in my other forum...
https://www.ecoustics.com/electronics/forum/car-audio/126956.html
