HELP NEEDED PLEASE
TMay20
what kind of amp would be ideal to run to 2 JL Audio 12w6? I am tryin not to get too pricy for an amp(<$400)?
Username: James1115
Wilton, Ct
Post Number: 1933
12w6's or 12w6v2's?
TMay20
12w6v2
Username: James1115
Wilton, Ct
Post Number: 1936
alright anything that is 800-1000 watts would be ideal for those subs. I am gonna recomend a JL 1000/1 but it is a little more then your budget. If I were you I would look into an Orion 250 HCCA that will do 800 -1000 watts at 1ohm. perfect match for the w6v2's. if you dont want ot get that look into any amp either 800-1000 watts at 4ohms or 800-1000 watts at 1ohm and it will work perfect for you.
TMay20
Where can find the Orion 250 HCCA for a reasonable price? Everywhere I see one it is about $530! I am not knowledgeable on the quality of certain brands, can you please name some amps that would work for what I am tryin to accomplish in the my price range?
Username: Invain
Michigan United States
Post Number: 1643
Well, if you want the G4 or GS then your gonna have to be patient. Trust me, lol. I've been waiting for quite a while for one. Just check ebay often.
Username: James1115
Wilton, Ct
Post Number: 1937
LOOK ON THE AMP SECTION AND LOOK UNDER ISAAC'S POST'S. 3/5 WILL RECOMEND ABOUT 5-6 DIFFERENT KINDS OF AMPS THAT ARE GOOD AMPS IN YOUR RANGE.
