MegaXtylez Unregistered guest | hi, How Can I Remove the faceplate of Sony CDX-L510X? http://www.cardomain.com/item/SONCDXL510X |
Silver Member Username: Marley289Post Number: 143 Registered: Nov-04 | the faceplate is the whole display screen, to remove that all you have to do is push the open button in the top right corner. if thats not what you are asking, then i dont understand what you are saying. |
