WANTED / NEED 60" Screen for RCA Rear Projection TV
Username: Daveh1010101
Ohio USA
I am in need of the ENTIRE SCREEN ASSEMBLY (2 Sheets / Pieces) for an RCA 60" Pro Scan Rear Projection TV.
This unit is only a few years old and is a 4:3 NOT a wide screen.
The Service Model Number is: P60812BBLG2
Thompson Eletronices (rca) no longer has any in stock. I am willing to pay a reasonable price and shipping for a screen in good condition.
I feel that most ANY 60" 4:3 Screen from most brands will fit or can possably be persuaded to fit.
I do know if the screen can be packaged in card board no bigger than the following sized: 39" X 39" X 4" then the shipping is around $20 If 1" larger the shipping jumps to over $70
If ANYONE has information, ideas or suggestions I Thank You in advance.
Thanks,
Dave
xvxvxvx
Try 1-800-956-4485, Mighty Shield can custom manufacture a replacement ecreen for any TV. Your size seems common and they will likely have an off-the-shelf replacement available.
xvxvxvx
