Trouble with NAD T752 A/V Reciever setup
jaeelarr
So basically,I can't get any sound out of my speakers.Ive tried a couple different pairs just to eliminate the notion that it could be the speakers and/or speaker cables.Then I figured it might be my coax cable going from my CD plyer into the receiver.So,I hooked it up with traditional RCA cables,and still nothing.Switched to the radio(FM and AM),still,no sound.I followed and tried every troubleshooting method they list in their manual index.Any suggestions???
jaeelarr
Is there a better place to ask this question?Im frustrated as all hell!
Username: Halej
MackenbachGermany
Have you looked at the recievers speaker selection. If you choose A and B you won't get sound from the surrounds either.
