MTX 8000 pharting
Username: Cory
Post Number: 114
HI all I got 2 MTX 8000 10" subs in a ported box connected to a MXA 4001 amp into 2ohms and gain set to half way on the amp
The subs sound fine at low volumes but when there is mid to high excursion from the sub it makes a sound thats if its pharting
Why are the subs sounding like that? is there a defect or bad box?
Username: Invain
Michigan United States
Post Number: 1210
It could be distortion, your gonna have to explain this pharting sound more....
(I am getting really mad at this forum's filters... you can't say pharting... are we in 3rd grade?)
Username: Cory
Post Number: 115
lol I know,I had to get creative...
When the cross over is at higher level say around 150 and the sub is forced into to doing some excursion at say 3.5mm each way it will start to have this heavy breathing sound and a high pitch muffeled one as well. But when I set the cross over to 50Hz its not as bad but can still be noticed when at mid to high volumes
Username: Cory
Post Number: 116
The box is 29*11.5*11(measured from the inside and the port is 7.5*7*1.5
hope this might be some help
Username: Invain
Post Number: 1217
Hmm, what's the rms on that amp?
Username: Cory
Post Number: 117
400rms into 12.5 volts at 2ohms
Username: Invain
Post Number: 1219
Well, you probably are clipping the amp, wich causes distortion to the subs. Each 8000 is 400 watts rms.
Username: Cory
Post Number: 118
you're probably right, do you think there power hungry subs?
Username: Invain
Post Number: 1223
Ehh, not too bad. I had 1, I ran it with an MTX 311D, 320 watts rms. Listen carefully to the music, and see if you can hear distortion or not. If it's bad enough you should be able to. I know there's someway to meter if your amps are clipping, not sure what you gotta do though. I would probably think of getting a bigger amp though.
Username: Cory
Post Number: 119
true true.....Bigger amp it is then,thanks for your info and time
Username: Cory
Post Number: 120
One thing JOe what do you think about MTX 9500 series? have you seen or heard it in person?
Just wondering
Username: Taylor17
Kopperl, Texas
Post Number: 821
It is a good sub, they compare it to the JL w7, but it isn't as good.
The 10's are close, but the bigger you get, the more JL sound's better.
Username: Invain
Post Number: 1226
Pretty much. The 9500 isn't bad, the best of the MTX line. Most of the subs in it's class will probably out do it though.
Username: Cory
Post Number: 122
ok then, what about the GTI subs from JBL would they by a challenge for the JL W7's?
Im looking at SQ over SPL
Username: Invain
Post Number: 1230
I dobt they'd match the w7's. If your looking for something somewhat in the w7 league, and with awsome sq, look into the w6v2's. They're supposedly the best sounding subs out there right now. You can also try Image Dynamics IDMAX, their known for their exceptional Sound quality.
Username: Cory
Post Number: 123
Can you give me a link to ID web site i cant find it/or cant spell...lol
Username: Taylor17
Kopperl, Texas
Post Number: 822
Yehp, the w6v2 is supposed to have the best sq out of all.
Username: Subfanatic
Walton, Ky
Post Number: 739
what do you guys think about the mtx jackhammer 22 inch sub
Username: Invain
Post Number: 1234
www.imagedynamicsusa.com
Yeah sub, I checked that jackhammer out. It seems like it would be more practical than the Audiobahn 36". Who know's how it sounds though. You wouldn't think it would have the fastest respones with a 22" cone though, but it should be loud...
Username: Cory
Post Number: 124
i think that if i could aford it i would buy it but really were you going to put it. (with the proper sized box) I heard from some were that you have to sign a release form that mtx is not responsible for any damages
Username: Invain
Post Number: 1236
haha
Username: Cory
Post Number: 125
thanks for the link. there IDmax subs look pritty cool
Username: Invain
Post Number: 1238
Yeah, if your going for sq, that's the sub for you...
(nice rhyme I might say)
Username: Cory
Post Number: 126
lol
Username: Cory
Post Number: 128
whats the size of the ported box you got for the 8000?
Username: Invain
Post Number: 1240
I had it in a 2.25 cf box.
Username: Cory
Post Number: 130
So were is it? now if I may ask
Username: Invain
Post Number: 1289
Right now, it's in some other dudes car.
Username: Araknid
BOCA , FL U.S.
Post Number: 295
Cory I think u should try putting it in a sealed box even if it is a cheap one. that should get rid of the sound I think.
Username: Invain
Post Number: 1293
HA. I didn't even realize you had a ported box...
You're probably also hearing port noise. In fact that's definitely part of the problem.
Username: Cory
Post Number: 133
well is there away to reduce port noise?
Username: Jmloughrey
Farmington, CT
Post Number: 965
...to reduce port noise...build a bigger port....whats happening is the air coming out of the box doesnt have a large enough space to exit the box, hence the port noise your probably hearing. try going sealed, or rebuilding your ported box with a different size/tuned port...
Username: Cory
Post Number: 134
well could i stuff the port with fiberglass and cover the port with a pecie of MDF? because i dont feel like going to buy another box.
Username: Araknid
BOCA , FL U.S.
Post Number: 308
you can do that, ull have to make the seal extremely tight. use some kind of qorking. screw on the MDF then qork the edges. (not sure if qork is spelled right but u know what im sayin right)
Username: Cory
Post Number: 135
Yeah I now what your saying mike, thanks for the info
