Are these subs any good
zackrude
http://www.fortunecity.com/skyscraper/black/438/rf/rfp2810.html
for a 10" sealed box in a truck
Username: Tragedy
San Jose, CA
Post Number: 23
Good in what sense?
The sub is 8 ohms with a nominal power rating of 200rms. Generally the higher ohm subs are paired with 2-4 subwoofers to lower impedances but i think this one is a single voice coil so running one only would require a bigger amplifier to push 200rms at 8ohms. Amplifiers dont show 8ohm ratings so if your stuck on this sub look for an amp that pushes 400-500rms at 4ohm. Look for a dual 4ohm subwoofer, i think that would be your best bet. Kicker Comp VR is always a great low-budget choice.
zackrude
would they sound good in a 10"sub sealed box in the back of my truck
thanks
Username: Tragedy
San Jose, CA
Post Number: 28
I am sure for what you are after they will be fine. I had a RF HX2 10" in a ford ranger with a compact size enclosure behind the drivers seat. Sounded good inside the cabin, but outside the truck the bass wasnt to great. Depends what your after.
