4 channel amp front/ rear technical question ?? help me....
Username: Armadalegq2000
Post Number: 25
if i have front speakers that are 3 ohm and 125 watts each (250 pair) and rear speakers that are 4 ohm and 50 watts each (100 pair)....i have a four channel amp thats does 150x4... can i run the front channels two speakers @ 3ohm and 187x2....and run the rear channels @ 4 ohm and turn gain down and run them at 50x2.....Can i run two different wattages and two differen ohms to the front and rear >>PLEASE ADVISE<<<<
Username: Nnnnick_b
Post Number: 23
yes, as long as the amp is stable down to 3 ohms, or 2. Shouldnt be ne problem.
