Doug W. Unregistered guest | I think I've heard something about connecting all 4 of the RCA cables to get more power out of the JBL BP600.1 amp. Is that true, if so how do you do it? Also about how many more watts will this help put out |
Silver Member Username: Joe718Brooklyn, NY Post Number: 299 Registered: May-04 | its nor really more power your just using all of the amps inputs which gives the amp a higer input signal. Just go to radio shack or an audio shop and pick up two Y adapter splitters. They have one female input and split inot two males. |
Doug W. Unregistered guest | So what exactly will a higher output signal do? |
Silver Member Username: Joe718Brooklyn, NY Post Number: 310 Registered: May-04 | you get clearer louder sound |
Doug W. Unregistered guest | so would it be worth it to get those if I am running a JBL BP600.1 to 2 12" Image Dynamic IDQ subs? |
Silver Member Username: Joe718Brooklyn, NY Post Number: 311 Registered: May-04 | yes you should, you will notice a difference. |
Gold Member Username: Jonathan_fGA USA Post Number: 3327 Registered: May-04 | Just to note, it simply seems to help those specific amps for some odd reason. It doesn't work on every amp and isn't a common procedure. You'll see benefit using Y splitters on all the inputs, though. |
Doug W. Unregistered guest | Are these what I'm looking for? http://www.amazon.com/exec/obidos/tg/detail/-/B00005T3FT |
Bronze Member Username: Jrz126Erie, PA USA Post Number: 11 Registered: Feb-05 | kinda, you'll need one with a single female end splitting into 2 male ends http://www.amazon.com/exec/obidos/tg/detail/-/B00006346W |
