Silver Member Username: Tevo
Chicago,
IL
Post Number: 148 Registered: Feb-05
Posted on These adjectives are used to describe the sound of a particular component. What is warm sounding to one listener might be neutral to another or vice versa. Compare receivers on features and power and then listen to them to decide which "type" is best suited for you. |
