REMOVE DYNAMAT
Username: Thatboye18
Post Number: 7
I have this s**t all in my car. How do i get it out?
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 502
Start pulling. Honestly I would just leave it. It will make your radio sound alot better, and keep the interior of your car alot quieter.
Username: Marley289
Post Number: 106
its pretty hard to get off it would take a lot of time. go with what jeremy said just leave it.
Username: Invain
Michigan United States
Post Number: 675
In all honesty, if it was installed correctly why would you want to pull it out? I'm under the impression you bought the car with it already in it. If it's real Dynomat than it was probably pretty expensive to do a lot of the car. The only reason I could see for you wanting to pull it out is the looks.
Post Number: 10
i dont think it was put in right. I have a 12w7 and it rattles very bad. i was going to get it spotted in some of the bad spots.
If it comes off, then it is not Dynamat or was not put on correctly. Try this.. dip the car in liquid nitrogen... No really, the colder the better.
For some reason, removing Dynamat doesn't seem like a good fix for rattles.
Username: Invain
Post Number: 727
If I were you just patch it up, and if you have to you could try getting the spray on stuff and putting a coat of that over top. In all honesty, it would take a TON of dynomat to quiet a 12w7. Your car is gonna rattle no matter what with that sub.
Username: Hdubb
Farmington, Nm Usa
Post Number: 815
just add more to it. ther more the better.:-)
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 21
i've heard you can use a heat gun to remove it but i don't think removing it will get rid of any rattles. like Hunter Warren says, the more the better
