Help please
nolimit182
Are these premade boxes by Alpine any good?
http://www.onlinecarstereo.com/CarA...ProductID=13203
tricksta420
your link isnt working....and if you have alpine sub(s) the alpine box will probably work good but there is always room for improvement when you make your own.
nolimit182
sorry here it is
http://www.hookedontronics.com/show_product_details.jsp?cid=4457
nolimit182
anybody
Username: Hdubb
Farmington, Nm Usa
Post Number: 745
it doesnt look that bad. i would say try it. its not bad being pre;loaded. its a 10in sub
