Whats so bad about the Audiobahn A8000T
i heard audiobahn was a good brand but all over the forum i hear ppl doggin the audiobahn amps. they look good especially for such low prices. do they break down, overheat or make rough bass? whats so bad about them?
Username: James1115
Wilton, Ct
Post Number: 721
They have a very high failure rate. For the price they are not the worst by any means but they arnt very reliable. for the money you can get better Ex JBL,MTX,Soundstream,Alpine....
i havent seen any other amp that produces 800W rms or anything near that for the $199 that the audiobahn costs. have you?
Username: Nwdmax
Post Number: 18
MODEL THUNDER 801D
TYPE Mono Subwoofer Amps
PRICE $284.90
FEATURES
MTX Thunder 801D
* RMS Power 12.5 VDC
-- 2 ohm load 500W x 1
-- 4 ohm load 250W x 1
* Hi level with smart engage
* Low level input
* Crossover:
-- Low pass @ 40Hz-200Hz-Variable
-- Compression circuitry
-- Thunder EQ
-- EBC2 port
* Dynamic power 14.4 VDC
-- 2 ohm load 800W x 1
-- 4 ohm load 400W x 1
* Low pass of RCA output
Username: Sancho886
El Cajon, CA US
Post Number: 76
yeah anon theres a reason for that. you really think they offer it for such a low price because it's good quality? you get what you pay for.
Username: Carguy
Post Number: 1550
I have personally tested A8002T amp and it is good for the money. A8000T is also a good model to purchase for $130. Not sure if you'll get 800W but so far, it's been giving clean power. Hasn't broken down.
