New member Username: Armadalegq2000Post Number: 9 Registered: Feb-05 | ? |
Bronze Member Username: Cb9869Post Number: 51 Registered: Jul-04 | No |
Gold Member Username: Jonathan_fGA USA Post Number: 3209 Registered: May-04 | The XBL^2 motor was designed by Adire Audio and patent pending, there are only a few companies (Resonant Engineering, Ascendant Audio, and a few others) that have the rights to use their design. JL uses it's own methods on the W7 driver. |
Silver Member Username: Rob_brownPost Number: 129 Registered: Jul-04 | it uses like some drill hole method or something, pushes cold in. cross piece drill. soemthing like that. it says on the spec sheet on the site. www.jlaudio.com |
Gold Member Username: Jonathan_fGA USA Post Number: 3215 Registered: May-04 | Cross drilled polepiece, which removes heat from the voice coil. It also has a forced air cooling frame, which basically adds a little control to the sub and cools the motor when air moves through the frame. Of course, it also uses a very well designed suspension system to keep things linear as well. Another thing you have to take with a grain of salt, the ID Max is a very good subwoofer and doesn't boast huge technologies, but sounds every bit as good as a W7 or Brahma. It accomplishes it's purpose with a very tight gap and well designed suspension. |
