Greg Williams Unregistered guest | I got this box and 3 subs at a drug auction. I opened it to find the ohm ratings on the subs and to figure the wiring. This image is what I found. I though it was kind of wierd so I thought to ask all of you. Should I remove the 2 in question or is it an ok wire job? http://www.imagehosting.us/imagehosting/showimg.jpg/?id=226224 |
Greg Williams Unregistered guest | By the way they are all SVC subs. |
