New member Username: WolfiPost Number: 6 Registered: Jan-05 | so i decided to get the creative ddts 100-decoder for my xbox, i also need a speaker system and the choice is beetween Altec Lansing 251 or Creative Inspire T-5900... i dont know wich one to chose so a little advice woud be much appriciated...wich one shod i buy? |
Bronze Member Username: Scotty2hottyChicago, IL Post Number: 49 Registered: Nov-04 | You shoulda taken my advice in the 1st thread you started and got the Panasonic SC-HT05. http://circuitcity.com/ssm/Panasonic-Home-Theater-System--SC-HT05-/sem/rpsm/oid/ 91691/rpem/ccd/productDetail.do |
Unregistered guest | I have a similar problem, i have jsut got a Soundblaster Audigy 4 Pro, ive connected the digital out of my Xbox (advance A/V) to the digital In on my Exteral HUB, i have creative T7700 speakers, i have all the digital options in the xbox menu ON, and i have set it so the HUB decodes it, not passes it thru to anything. But i can't get sound from my Xbox onto the speakers (the speakers are working, winamp etc plays normal sound), any help would be nice. |
