How to wire 3 jl audio 15s with 4 ohm single voice coils
i have 3 jl audio wo15s 4 ohm my amp is 2 ohm stable (infinity 1210a mono amp)how can i wire these subs to get max without frying my amp ?
Username: Cdj
Southern Ohio
Post Number: 11
Wiring your 3 subs together gives a 1.34 ohm load. You'll really need a 1 ohm stable amp for that configuration.
Here are some wiring config sites so you can see for yourself:
http://www.precisionautosound.net/subwooferwiring.html
http://www.sounddomain.com/shop/wooferwizard.pl
http://www.infinitysystems.com/caraudio/sub_wiring.aspx
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
