1 channel run to subs?
im kinda new to subs and was wondering if i have 2 subs do i need a 2 channel or can a 1 channel sub power them both please treat me like an idiot becasue i have no clue what the dif is
Username: Carguy
Post Number: 1451
You can use 1 channel amp to power 2 or more subs. All you have to watch out for is the amp's minimum ohm requirement.
here is my sub im not sure what its ohm is but can u also recommend and audiobahn sub that would power them under 350$ ???
AWES12P x 2 qty
Key Features:
12" High-performance subwoofer
3-Layer poly cellulous core cone material
180 oz. strontium magnet
Dual voice coil wound on black anodized aluminum former
Multi-connect lug lock terminals
Chrome plated 3-dimensional cast aluminum basket
Flat progressive NOMEX Spider
Aluminum basket and magnet mesh cover
RMS power handling: 1100 watts EACH SUB!! (4400 watts max power per pair!)
Frequency response: 18 - 500Hz
Sensitivity: 92dB
Subwoofer Specifications:
Subwoofer Size: 12"
Impedance: Dual 4 ohms
Dual Voice Coil: Yes
Peak Power Handling: 4400 watts approx. Per Pair / 2200 watts approx. Each Sub!
RMS Power Handling: 2200 watts Per Pair / 1100 watts Each Sub!
Surround Material: PHAT 2? Foam Surround
Sealed Box Volume: 0.75 - 1.75 cubic ft.
Ported Box Volume: 1.0 - 2.8 cubic ft.
Sensitivity: 92dB
Frequency Response: 18 - 500Hz
Top Mount Depth: 8-5/8"
Cutout Diameter: 10-7/8"
Warranty: 1-year SE
