Bailz Unregistered guest | I have a Cerwin Vega HED 12 DVC sub. I know it as a rms handling of 200 watts. I just don't understand what kind of amp to put up to it. http://shopping.yahoo.com/p:Cerwin-Vega%20HED-12DVC%20Car% that should have the specs.. it says 2/8 ohm.. so.. is it liky my choice of which to run it at? Seems like it'd be a lot cheaper to run it at 2 ohm, right? a 200 watt 2 ohn amp is cheap generally. Thanks in advance. |
Silver Member Username: Taylor17Kopperl, Texas Post Number: 400 Registered: Jan-05 | If you run it at 2 ohm's, the amp will put out a lot more power than it would at 8 ohm's:-) If you only have 1 sub, then wire it in paralel down to 2 ohm's. When looking for an amp, just see what it put's out to 1 sub at 2 ohm's and match it with your sub. |
