What amp would be best
Username: Luc89
Post Number: 16
What amp would best run with my subs. I have 2 12' audiobahn AW1206T. They are underpowered right now n i need a bigger amp. so what would best run with those subs. Thanks
Username: Xxkmfdmxx
FL USA
Post Number: 303
I'd go with a ORION 2500D. It isn't cheap though.
Username: Marley289
Post Number: 77
whats your spending range?
Username: Luc89
Post Number: 17
spending range is ne were from $200 to $700. But if the amp is worth it, I might be willing to spend more.
Username: Geekbike
Post Number: 38
You can occasionally find a 2500D refurb on ikesound.com for a great price.
Username: Sparkey2027
Barnstaple, England England
Post Number: 64
id get an audiobahn 2300 hct. it gives out 2400w @ 1 ohm. it ll do the job. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48597%26item%3D5749707875 &tc=photo
Username: Luc89
Post Number: 18
Hey thanks josh walton, I like the audiobahn amp better than the orion cuz i want to do an all audiobahn sound system. That info definitly helped me out. thanks
