it must be 4 ohms because 3.20 is what subs are usually rated at in the instruction manual. it just says 4 ohms to make it less confusing. if this is the case, wire them like....
whoa what is going on in that diagram....so i wire the neg to the neg and the plus to the plus and then run one wire from one of the pluses and one of the negativs(does it matter which one)....and do what with it
This was ez for me. RESE voice coils have Alan renchs to tighten wire in there. anyway you take spare wire and go from plus to plus(if you have a box with wire inside that goes to the back, you put the plus of that in there with it) and same for the neg but all neg, then plus to plus on and the same for neg to neg. if you put the plus on the neg and same for neg to plus you sub will work backwords. so make sure you wired it right.
ThatGuyYouKnow
Oops If you switch the speaker wires on the amp it will work backwords.
