Anonymous | I want to buy a 12" brahma but where should I buy it? Everywhere is backordered and i have everything but the sub. Is there a cheap sub that will get me by until the brahma comes? I have a kx1200.1 so i can run just about anything. WHAT SHOULD I DO????? |
Silver Member Username: HdubbFarmington, Nm Usa Post Number: 562 Registered: Nov-04 | when you finally buy one go through www.acoustic-visions.com free shipping. they some how got me mine, a lil bit a go, i think x-mas is when i got it and they were on back order till jan. he said. i got real lucky and will always plug them. a cheap sub to get you by huh...try an atlas, www.ascendantaudio.com 140. and it will be worth keeping after that. it uses xbl^2 tech. just like the brahma. or you could get a shiva if they arent on back order. |
Anonymous | one of my friends just gave me his old soundstream spl i think that will due fine. thanks for the help I think im gonna order the brahm. is there anywhere where it is not on backorder? |
Silver Member Username: James1115Wilton, Ct Post Number: 477 Registered: Dec-04 | nope! |
Silver Member Username: HdubbFarmington, Nm Usa Post Number: 576 Registered: Nov-04 | if you hurry you can get this 15 brahma off ebay http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18804%26item%3D5747635428 %26%26 if you want it and if you are registered |
