I have a 1997 saturn sc 2 door coup. The stock speakers are blown to crap. They are 5 1/5 inches. I wanna put some bigger more durable speakers in there place, like some 6 by 9's but i was wondering if the 6 by 9's would fit in the same place as the smaller stock speakers. Thanks for any replies
no, not unless u did some crazy custom work. get a decent component set from alpine or infinities lower lines, or give us a budget and we can give u some more options.
