VCR to Receiver hookup
newtoa/v
Does anyone know if the Onkyo tx-sr502 receiver that comes with the Onkyo 770 Home Theater System can convert composite video input signals to component video output signals for a tv? In other words, can you run the composite cables from a VCR to the receiver and have component video cables running to the TV. Thanks!
Username: Dirtfarmer
Alberta Canada
Post Number: 383
hello
go to this site that i spend a lot of time working on i sure it go some answer for you
Message Board: Home Theater: Home Theater Setup & Planning: The ultimate theatre setup guide
Use this link to go directly to the discussion:
https://www.ecoustics.com/electronics/forum/home-theater/113395.html
