Help with setup to set sound TV > Home Theater
Username: Bl1nd
Ok i got a 21" Sony Triniton TV the flat screen one well it got 2 Audio/Video IN and 1 headphones and 1 UHF entry i wanna know how i can connect the TV to sound in my home theater
My home theater is a simple one daewoo DHC-x150 is dvd /home theater etc etc
My home theater got audio in and video i wanna know if there is a way to hook up my cable on my dvd/home theater
If my tv doesnt have an output well the headphones output :s well i guess i could connect the cable but it is a vhf/uhf cable the one with a spike in the middle white cable
well i got no idea :s
Username: Dirtfarmer
Alberta Canada
Post Number: 338
Message Board: Home Theater: Home Theater Setup & Planning: The ultimate theatre setup guide
Use this link to go directly to the discussion:
https://www.ecoustics.com/electronics/forum/home-theater/113395.html
Jose Manule
Buy a 3.5mm headphone jack > 2 phono cable from your local electrical / hardware store. Plug the jack into the TV and the phono into the Daewoo.
