Bronze Member Username: RunthunterPost Number: 18 Registered: Dec-04 | Where is the best place to buy a good dash kit for a 2000 s10? I seen some on ebay and was wondering if there is any brand I should be looking for as far as fit and finish and quality.Thanks |
MPH Unregistered guest | You should contact Crutchfield via phone or web (www.crutchfield.com). I've always liked their kits because their clean and easy to install. |
Bronze Member Username: NnivesPost Number: 12 Registered: Jan-05 | Scosche makes the best. Ebay is a good place to compare different products. |
