New member Username: Broker3460Post Number: 1 Registered: 02-2004 | I just went to bestbuy and bought a new 65" Mitsubishi HDTV model:WS-65313 it has a dvi connection and a RS-232C connection here is a link to its specs: http://www.mitsubishi-tv.com/ I also have a new computer I bought from bestbuy it is a Sony model: PCV-rs530g which has ATI Radion 9200 128mb with VGA, DVI, tv-out here is a link to its specs:http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_Display ProductInformation-Start;sid=PQlUgm0MAV1UlS0luJFeiSICAL14bEuCy4I=?CategoryName=cpu_VAIODesktopComputers_ RS2Series&Dept=cpu&TemplateName=item%2fsy_item_b&ProductSKU=PCVRS530G Now here is the problem I called Sony they told me i needed to call the Mitsubishi to get a INF file (what ever that is) so I called them and they have no idea how to do anything. no conclusion there. Heres the problem I cant get out of 480x720 resolution. Ive tryed everything with my tv and the computer. I have it hooked up using the DVI. I'm stuck, is it me, my hardware or is it the TV will not support a computer hook up? Please help anyone. Also, I'm a little illiterate when it comes to this type of stuff so be gentle. Thank you, Tony |
