I recently bought a Sony CDX-M8800 headunit which has MP3 playback. However when I try to play MP3 CD's it it just displays ERROR and ejects the CD. It plays regular CD's without any problem. Any help or advice for this problem would be much appreciated. Thanks, Ed
i was having the same with alpine. i used to drag and drop all my mp3 files and make mp3 cd. it would skip like hell. then, i started making folder and then burn it; it was playing fine. suppose you have 100 songs. so, you need about 5 folders which means about 20 songs per folder. try it.
my friend's sony deck (don't know the model but it's a couple years old, the one with the dual face that flips around) works with some CDR media and not with others, so try a different brand media. i have no idea why this is, but it does the same thing (ERROR screen).
They're normal MP3 files. I think I know what the problem is - my CD recorder. The hu plays CD's copied by my mates so Im guessing its just mine that is incompatible. V.annoying! Thanks anyway.
