Johnny Bravo Unregistered guest | hawk I saw you mention magnepan speakers I am not familar with them can they be used for ht looking to set up 5.1 budget around $1200 I have a yamaha sw-80 if I could integrate it Thanks, Johnny |
Johnny Bravo Unregistered guest | By the way hawk I am purchasing a nad 753 Johnny |
Silver Member Username: HawkPost Number: 267 Registered: 12-2003 | Johnny: You will need the NAD as the Maggies are true 4 ohm speakers and they won't even sell you the MMGs unless your receiver/amp clearly states it will drive 4 ohm speakers. The MMGs are $550/pair. The matching surrounds are a mere $299/pair and the center speaker is $299, as well. That is ~$1150 for the lot--delivered! No better speaker, IMO, for either music or HT. Here is a review of the MMGs: http://www.goodsound.com/equipment/magnepan_mmg.htm Here is the Magnepan website where you can order them--you have to call them (toll free): http://www.magnepan.com/ Simply click on the link for "An Offer We Hope You Can't Refuse" on the upper left. They come with a 60 (not 30) day trial period. As I have said before, my wife objected to large floorstanding speakers, so I sent mine back (regretfully, I might add). When I called for an RMA, they only asked why I wanted to return them and I told them my wife objected to floorstanding speakers. They were very understanding and I had no problem--my credit card was promptly credited. However, I will tell you that they are very hard to return emotionally. I loved those speakers. I don't know your sub, but integrating it shouldn't be a problem. Enjoy! |
