I just got an 18" MA Audio (MA18XE) its the 2002 model and im wondering if I should go with a vented box which would make it loud or a sealed box to keep it tight, well as tight as you can keep an 18. I want it to be loud, spl is my main goal, but is it worth the extra $$$ to go with the vented? Thanks for your help
