Need help with sub info, and any other help plz
Username: Chris_streak
HEy, i recently bought 2 12" L.A. Sound subs and a 1200 Watt mono channel 2 way amplifyer by the same name. I have a alpine 9835 Cd deck. Im putting toghether the sub, but i havn't desided what type of box to get, i love low bass but also listen to a large range of music so im not sure which type of box to get. Also im thinknig of getting grills but does that take away sound quality? If you have any suggestions for this or any other ideas for my van( yes soccer mom van) then please email me at chris_streak@hotmail.com tx
Username: Taylor17
Kopperl, Texas
Post Number: 148
No the grills don't effect the sq. It depends on how much room you are willing to give up!
A ported box would work nice, but the boxes require a little bit more room than a sealed box does. The ported box will make your subs a little louder, and the sealed box will give it a little better sq!
Ok, tx im still not sure yet.,..might go with carpeted sealed box, anmd i have alot of room, 1995 windstar, but i want a sub i can remove and put abck in kidna deal
