Can i hook up 2 4ohm subs to a 2 channel amp
Username: Blcketnies11
Can i hook up 2 audiobahn 12 subs that are 4ohm to a 2 channel rockford amp
Username: Bass_lover
Post Number: 12
yes, just make sure the amplifier is also 4ohm per channel and you shouldnt have any problems.
Username: Glasswolf
Post Number: 1111
if they are single coil subs, you put one sub on each channel.
you'll get a stereo 4 Ohm load.
If they are DVC subs, bridge the coils of each sub in parallel for a 2 Ohm load, and place one sub on each channel for a stereo 2 Ohm load.
ideally with a 2 channel amp, you'd want two 4 Ohm per coil DVC subs, or keep those Audioblah subs you purchased, and get a monoblock sub amp to drive them.
Otherwise you can't get an ideal load from a stereo 2 Ohm stable amp, and two 4 Ohm subs.
sorry.
