Advanced AV Connectivity Questions
Username: Viper1mx
System with relevant In/Outputs:
Television: Toshiba 62HM84 -- HD Ready
Video In: 1 HDMI w/ HDCP copy protection, 2 Component
DSS: Voom Motorola
Video Out:1 DVI, 1 Component
Audio Out:1 Optical, 1 Coaxial
Receiver: Kenwood VR -- 8070 - 7.1 THX Certified, Up-Converting
Video In:3 Component, 5 S-Video, 5 Composite
Video Out: 1 Component
Audio: Digital Audio Inputs: 2 Coaxial, 2 Optical
Digital Audio Output: 1 Optical
DVD: Sony DVP -- NS945V Up-Converting
Video Out:HDMI digital interface, 1 Component
Audio Out :1 Optical, 1 Coaxial
Xbox Xbox
Video Out:1 Component
Audio Out:R/L Analog
Speakers: JBL SCS 300.7
Audio: 7.1 w/powered sub
I'm at a loss for the optimal set up for this system, I've had a couple of recommendations but I'd like to see some ideas out here.
Plan A: Utilize HDMI from the DVD direct to the TV, along with optical to the receiver for full surround and THX effects, but with the HDMI carrying both audio and video, will the optical send the audio thru the receiver as well? DSS to receiver via component and optical connections, Xbox to receiver via component and analog connections.
Plan B: Take HDMI from TV, convert to DVI out for the DSS, connect DSS optical out to receiver. DVD to receiver via component and optical outs, Xbox to receiver via component and analog connections.
Plan B has some obvious issues, HDMI to DVI not always compatible, DVD HDMI auto-optimization lost. I'm open to suggestions here, so if you have an idea or other issues that need addressing, drop a note!
Thanks
johnm
I'd run a simple test to find your video preference. Run the Motorola to the TV using both the component and the HDMI. Watch a channel that broadcast a true HD picture. Now switch between the two inputs on the TV to see if you notice a considerable difference.
Do the same with your DVD player using a high quality DVD.
While Plan A seems like the logical choice to me, (optical audio out will work from the DVD player while using HDMI), your real concern is which HDMI source will give you a better picture and which one do you prefer since your tv only has one HDMI input.
