Plasma tv
Username: Nicehitsam
Kansas city, Missouri Usa
I have a 1 inch black bar (vertical) down my tv screen and a bad componect connector can any one repair this?
arrow224
This blach bar, is it on the actual display panel? If so, using the remote, there should be a 4 way directional pad/dial. Press in the direction you want the image to go, and it should do it.
this vertical bar is on the screen when I turn the set on its on the left side when I go to menu
I scroll down to the 4 directional arrows buyt this only allows me to position the PIP
816-806-0789
816-756-0307
