Mmats...
Username: Killer44
Ontario Canada
Post Number: 61
anyone know if a web site or dealer near the southern ontario region were i could get a 12inch mmats juggernaut or dreadnaut for cheap....i know theyre an expensive sub so im ready to spend around $450-$600....and what type or amp would be good to power both of these...and with this sub(either one) would it be a good idea to get dynamat??
Username: Jmloughrey
Farmington, CT
Post Number: 754
dynamats always a good idea...look into a cheaper route with it though then getting actaul dynamat brand stuff, look into edead from elemental designs or better yet water/ice barrier from your local hardware store...
check this link...
http://www.sounddomain.com/memberpage/337124/6
Username: Killer44
Ontario Canada
Post Number: 62
thanks ill definately look into that...anyone know about the subs + the amp thou...?
Username: Killer44
Ontario Canada
Post Number: 64
anyone know..?
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 146
I didnt quite understand your question but i think you mean do they sound good. But if you did, the jugernaut is a straight spl sub, and there amps are ncie as hell, and pack alotta punch to be so small
