Bronze Member Username: MrdarkPost Number: 17 Registered: Dec-04 | ok. Two DVC 4 ohm woofers wired in parallel make each a 2-ohm load. If i take both those loads and have one speaker's negative and the other speaker's positive going to the amp bridged, (subs connected to each other, negative to negative, positive to positive)will this drop it down into a one ohm load, or stay at 2 ohm load? Thanks to all who care to lend a helping hand. |
Bronze Member Username: Taylor17Kopperl, Texas Post Number: 14 Registered: Jan-05 | I think it will be a 2 ohm load. not sure! |
Silver Member Username: SolacedagonyNew Jersey US Post Number: 164 Registered: Oct-04 | http://www.rockfordfosgate.com/rftech/wiringwizard.asp |
