depends on what you want, and what you like. there's really no telling which will sound better because it mostly personnal opinion. Some people like the way ported enclousures sound and some like the way sealed enclousures sound. But if youre looking for more spl at certain frequency's go with a ported. If you like a flat respense go with a sealed. IF you looking for all out sq go with a AP box(if you have a trunk. And all with a ported box becareful because yeh you can can have more output of a ported box only if tyhe box is built correct. IF not you can actually end up loosing sq and spl.
