Question about modding a head unit
tonyz
i own an acura rsx s-type, which has a bose head unit. the unit includes a 6 disc changer, and a cassette deck. i'd like to connect an aux input to the unit, but unfortunately it doesn't have any kind of support for doing this. does anyone know if a mod like this would work:
the hack would require opening up the head unit. i never use the tape deck, so i don't mind if i lose its functionality. if there are audio wires that go from the tape deck into some kind of audio switchbox that controls whether CD, tape, or radio is playing, i could cut the wires from the cassette deck. then, i could splice in wires from an aux device, and use the tape button on the head unit to access its input. obviously, this wouldn't work if the audio switching is done on a computer board or something. but if the head unit is put together something like a home rack stereo, this might be do-able.
any thoughts?
thanks
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7153
just use an adapter fro PAC www.pacaudio.com to adapt the bose amplified system for aux inputs.
tonyz
hmmm, that website doesn't show anything. anywhere else offer that adapter? how exactly does it work?
thanks
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 153
Use a RF modulator and play your aux through the radio. Same thing that satelite radio uses.
Username: Glasswolf
Post Number: 7170
http://www.audiowarehouse.peachhost.com/Home.htm
they carry pac products.
sorry about the other site.. it worked last time I looked.
the RF modulator is an option as well
tonyz
i'm using an RF modulator now (satellite radio is what i'm hooking up, actually)... it's not bad, but i get some static bleed. the radio spectrum is full where i live, so it's tough. plus, the volume is a little low.
anyway, i emailed PAC and they told me they don't make an adapter for my car :-( guess i'm stuck w/ the modulator or maybe i'll just open up the HU and try and figure out how it works.
