JVC TH-M65 HTIB with Sony STR-DE997
Username: Semperfi91
I recently purchased a JVC TH-M65 HTIB without the DVD player/receiver.
I have a Sony STR-DE997 receiver that I'd like to use with these speakers. However, the subwoofer appears to have a unique cable that will only connect to the JVC DVD/receiver.
Does anyone know if it's possible to use these speakers and sub with the Sony receiver or do I need to find a receiver for the speakers? Thanks.
Username: Project6
Post Number: 2276
Is the subwoofer powered or passive? You can use the other speakers except for the subwoofer if it is passive, it is probably being powered by the JVC receiver internally.
Unless the sony has its own subwoofer amplifier then I won't use it.
The subwoofer is powered. I looked at the back of the Sony receiver and there isn't a connection like the one that the JVC subwoofer has.
Username: Project6
Post Number: 2302
Sony should have a subwoofer output called LFE output.
