Directv
Username: Cardkicker
Iso 7816 Pinouts,,, I have my prefered software for recieving the data threw an serial port. I am having problems reseting the cards.
power = is on
ground = is on
i/o = is at pin 2 on serial port
clock = is on.xtal T18.482 with 2 22 uf capacitors brown black and yellow resistor accross the crystal,,,
running threw an 74hCT04N inverter.
connected to the clock pin.
reset = resistor from V++ to RST & 10 uf capacitor from RST to ground.
the reset switch is conected to drain the capacitor when pressed.
SOMETHING ISNT RIGHT???
i probed the reciver Por = "Power on reset"
the i/o is high on the reciever pin?
