P3
Username: Whitedawgyt4
Hi I was wondering if anyone could tell me if you buy a mikobu card programmer but you have a direct tv reciever that uses a p4 card can you buy a virgin p3 card the one with the football player on the front program it and put it in your direct tv reciever?? also what about if the card is not a virgin and you use that program extreme Hu on your computer to wipe the card clean and then program it will it work in your direct tv reciever??
Username: Knee_grow
Detroit
Post Number: 99
Are you serious? Please tell me you are joking. You need to be educated fruit-tart, I suggest that you read a little more or there are idiots on here who will flame you to death.
Username: Tazspin
Post Number: 243
start looking at what happened at the end of april of last year (hint it has something to do with why hu cards wont work)
man why can't yawl save this newbie the time and just tell me or actually what would you guys recommend I buy or work with??
Username: Jmill1948
Chester, Va Usa
Post Number: 442
p3 is dead go with fta
what is FTA??
largo key
Chris...go do some serious reading for about 2-3 weeks at a reputable Dss site...U have a long rode ahead!
largo key
Chris go read for 2-3 weeks..U have a long road ahead!....start at [link removed]
