New member Username: Yoy0masterPost Number: 6 Registered: Dec-04 | I'm buying a 15 inch diamond CM3 sub and would like to know a recomended sub box design (like depth, width maybe even a diagram) so my dad can help me build it. Thanks very much, Andrew |
Silver Member Username: Koz1031Monticello, In United states Post Number: 341 Registered: Jul-04 | check their website and see what they recommend. Most ususally do. If not you will have to deside what type of box you want. sealed,ported. and how big you will want it. after that it's pretty elementary. |
Bronze Member Username: Eric77Post Number: 61 Registered: Nov-04 | go to www.diamondaudio.com then email their tech support and ask for box plans for a ported 15" cm3. They should have something. |
