Bronze Member Username: KklaggePost Number: 11 Registered: Dec-04 | How exactly do you use one of these to check the output of your amp (such as when setting the gains correctly)? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 6663 Registered: Dec-03 | www.teamrocs.com has FAQs on that |
Bronze Member Username: KklaggePost Number: 12 Registered: Dec-04 | Thanks Glasswolf...in your opinion is this a good way to set the gains in lieu of an oscope? I don't always trust my ear (wife says I sing like I'm tone deaf) |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 6671 Registered: Dec-03 | hehe yeah it's a good ballpark method. close enough to prevent damage anyway |
Bronze Member Username: KklaggePost Number: 13 Registered: Dec-04 | Thanks...I figured it was better than just using a regular DMM....Radio Shack sells one for about $90 |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 6680 Registered: Dec-03 | its always good to have an AC Voltage DMM anyway you can test wall outlets with that now too |
