Wiring question
Username: Rc_raycer
Will a sub sound the same whether it is wired into 2 or 8 ohm operation.
Username: Carguy
Post Number: 906
That'll depend on the amp. Most car amps will operate better at 4ohms, not 8ohms. As you go lower in ohms, the output power will increase. However, do not exceed the amp's limit.
Username: Oleg
Santa Monica, CA USA
Post Number: 200
For subs, 2ohm is good.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6679
the impedance will affect the amount of power the amplifier supplies to the speaker(s).
