Home Theatre Problem
Slims
Good Evening - we have an HDTV (Sony) and have a home theatre system (Koss - box set) with receiver/DVD player. I was finally able to get the system speakers to pick up the cable TV by using an optical audio cable (orange) from the cable box to the receiver...however, there is an audio delay (1+ seconds) and the voice and picture do not match up. The TV sound is right on...any suggestions on what I am doing wrong with the receiver? Confused...Thanks!
Brian Parsells
I am having the same problem with my samsung lcd tv and my sony surround sound. Did you figure out what the problem was?
Anyone else know what may be causing this?
Username: Project6
Post Number: 2128
a good read
http://www.techweb.com/wire/26804544
