jeffffffffffffffffff Unregistered guest | i was looking at adire shivas, but theyre hard to find anymore, are there any others that would be a good match to the amp? my price limit is ~$250 |
Bronze Member Username: SuicideshifterBristolville, Ohio United States Post Number: 66 Registered: Jul-04 | http://www.acoustic-visions.com/~acoustic/products/subwoofer_drivers/adire_shiva / try this site, i have 2 shivas and theyre great. using a 1200.1 will void your warranty, it will reach full xmax at 300 watts to each in a 1.5 cu.ft box. they can handle 600 watts to each but you wont need it. they are great subs, you will like them. |
jeffffffffffffffffff Unregistered guest | why would the 1200.1 void the warranty? because if this is true, i may want to consider other options |
Silver Member Username: JmloughreyFarmington, CT Post Number: 571 Registered: Jul-04 | The subs reach full excursion at 300rms, they can thermally handle well over 300watts rms so basicaly you'd be sending them un-needed power. That un-needed power would ecentially void your warrenty. in that case...get 4 shivas? MMMMM thatd be nice... |
