Converge
Username: Araknid
Post Number: 55
I had an idea today on making a duo enclosure by taking a sealed enclosure and a band pass and converging it together and srewing the speaker dead in the middle. what do u think? would it have the hard hitting of the sealed plus the higher sound of the bandpass? or something like that.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6413
do what?
a bandpass enclosure conceals the driver inside the box, with sealed on one side and vented on the other side of the speaker for 4th order, or vented on both front and back of the sub for 6th order.
I have no idea what you're trying to do.
you may want to research just what a bandpass box really is before trying to engineer some new type of box.
Username: Araknid
Post Number: 57
ok not the sealed but other box looks like this
_________
!OOOOOO!
!OOOOOO!O!
!OOOOOO!O!
!OOOOOO!O!
!OOOOOOO!
OO = free air
the sub at the top and the air goes down and up out the side. this is not bandpass? or wait its ported right. Can I use paint to show u a accurate diagram of my box plan?
Username: Redskin
LondonEngland
Post Number: 86
Ah yes thats much clearer???????????????
Username: Araknid
Post Number: 58
the piant file im trying attach says its to large to upload how can i do it without doing the diagram over again?
Username: Araknid
Post Number: 59
paint sorry
Username: Araknid
Post Number: 61
or am i doing something wrong GlassWolf any idea?
Username: Jmloughrey
Farmington, CT
Post Number: 532
make it a JPG file not a BMP...worthless BMP files
Username: Araknid
Post Number: 62
Username: Araknid
Post Number: 63
got it finally -- well?
Farmington, CT
Post Number: 534
you basically drew a bandpass box dude...
JuNGLiST
You sir, are a c0ck.
Username: Araknid
Post Number: 64
really..... damn......
Username: Araknid
Post Number: 65
how about to subs facing each other in a sealed enclosure, battling each other but it would have to be completely custom and handmade and im not in the mood for another diagram.
Username: Araknid
Post Number: 66
no because if it was a bandpass the sub would face away from the hole.
Farmington, CT
Post Number: 535
pretty sure thats a isobaric enclosure...
Username: Araknid
Post Number: 70
ok I know alot about car audio but isobaric is?
Username: Help_2
MN
Post Number: 19
clam shell...
2 subs mounted facing eachother...
Username: Glasswolf
Post Number: 6451
your drawing is fo a 4th order bandpass enclosure.
that's the type you see at best buy made by q-logic and sold for about $50.
sealed behind the sub, vented in front, or vice versa.
here's some info on box types with photos:
http://www.diysubwoofers.org/
check out each link on the left menu on that site.
look at the images and read up on em a bit.
then tell me what ya think.
Username: Solacedagony
New Jersey US
Post Number: 138
What you did was inversely mounted the sub in a 4th order bandpass. Like if you took a sealed enclosure and mounted the sub magnet out.
