Sonoma Setup
So far all I have is a Kenwood KVT-715DVD, I have a 2000 GMC Sonoma Ext. Cab, I am looking for an SQL setup, i have $1300 to spend on subs, amps, speakers, wireing, and enclosure supplys. Also i would like some ideas on types of enclosures to build (ie downfire, sealed, ported, into seats, up)
bump
Username: Help2
Well...
Are you gonna amp the speakers?
are you looking at component sets or
coaxials?
Next...do you want speakers just up front, or do
you want some rear-fill, and will you be amping
both?
For an enclosure...
youd be better off with a low tuned ported
box for SQL...most likely back-firing or
downfiring.
Wiring the amp(s)...youd best look at knuknoceptz.com
they have great deals on wiring kits, at a more than
fair price.
Subs/amp for subs will depend on the other stuff..
Username: Help_2
MN
Oops...First post as a member
and I f'ed up my name...
ah well.
Im just looking for front componants and i can probably find an amp on ebay for it
bump
Bump
Username: Help_2
MN
Post Number: 23
If I were you, Id jump on the deals at eD.
For 800 bucks shipped youd get a complete
system(2 amps, 2 subs, and an awesome set of component speakers.)
you can spend the remaining cash on wiring
and a custom box, and electrical system upgrades.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 69
re 12" X.X.X - 405
hifonics bx1000d - 200-230
knukonconceptz wiring-75
enclosure supplies - 50
thats 900 so far. 400 left for insides spearkers and amp
