Bronze Member Username: GinuwinepzPost Number: 26 Registered: Aug-04 | ok...i have a very low budget right now, but am looking into getting an alarm system for my car for stereo equipment reasons...any ideas on what is good for cheap (if that is possible)? and easy installation |
Silver Member Username: JeremycKunsan AfbSouth Korea Post Number: 269 Registered: Jun-04 | Andy save your money. About 250 to 300 should do. No alarm is easy to install, and this is comming from a guy that works on electrical systems day after day. Not to mention cheap alarms have a very high failure rate, and go off all the time. I would try for a low grade clifford. I promise you will be alot better of in the long run. |
Bronze Member Username: Ps1k0Post Number: 78 Registered: Aug-04 | i would recommend the K-9 mundial, from omega. as a good cheap alarm. i installed one in my brothers car for christmas 2 years ago. and he's had no problems. http://www.etronics.com/product.asp?stk_code=omek9mundial2&store=&catid=297 although you do get a better alarm with more features for more money. and i want to say that IMO the alarm isin't hard to install. it's the car that makes the install easy, hard or i'm going to hurt someone difficult. |
