Anyone with a Panasonic PT50DL54?
Username: Edaudiyocom
Post Number: 15
I did a search and found two hits... Rating from the end-user wasn't good but the http://www.dlptvreview.com/ rated it in the top 3??
Username: Triedit
Nashville, TN USA
Post Number: 16
I have the PT50DL54. I looked at every brand and type and preferred the Panny. After getting it home and using both DTV and cable the PQ is much better thatn I expected. The only problem is fan noise, however, it seems that this exists on all brands of DLP.
I spent last Saturday looking again because I do not like the fan noise. The only set that I might consider is the Sony 55XS. I will likely exchange for another Panny because I can not find another that matches it's PQ in my opinion.
